CEILING MAX vs DROP CEILING... ALL OPINIONS
Old 02-27-03, 09:01 AM
jckftrds
I ve discussed this before i was going to use the CEILING MAX SYSTEM, but I heard that the runners ahve a tendency to warp across the joists if the joists are not level. the other option in a traditional drop ceiling which would require me to use furring strips or blocks to lower the ceiling to clear the pipes that run across the joists. drywall or painting the ceiling is not an option
what should i consider doing
Old 02-27-03, 08:41 PM
Bluestraw's Avatar
Re: CEILING MAX vs DROP CEILING... ALL OPINIONS
Why not just use longer wire when hanging the ceiling? Also, how were you going to bypass this using the CEILING MAX SYSTEM?
