water proofing suggestions
Old 03-27-03, 11:46 AM
620east
I have installed a sump pump. cleaned my gutters and I still have a small amount of seepage in a corner. It was suggested to me that I dig to the footer and apply a waterproof product to the wall. It has been a very wet winter. I can dig it myself, do you have any other prevention methods that I can do once I have that side dug up? FYI ,I have a lot of clay in my yard.
Old 03-27-03, 08:13 PM
Doug Aleshire's Avatar
620east,
Did you just install a sump pump? No under cement drain tile or other methods used to direct water to sump pump basket?
Old 03-28-03, 06:00 AM
620east
Yes. We do have an under the cement drain going to the sump. The contractor put on a pipe with holes in it wit h gravel around it.
Old 03-28-03, 07:25 AM
620east,
If the drain tile is around the entire perimeter within the basement, what are the current conditions outside that might be contributing to this? Is there a need to improve some issues outside as this seems to be a possible source of problems.
Take a look at this link for some ideas...
http://www.dspinspections.com/basementwater.htm
Hope this helps, let me know what you think.
