Connecting Plastic tubing to PVC Drain?
Hello
I am finishing my Basement bar and am installing a new drip tray with drain hole for my Kegorator. I want to use Plastic tubing from my drain hole and connect it to the PVC Piping that is the drain from the upstairs sink. It is only about three feet away. What type of connector should I use to connect the plastic tubing to the PVC pipe, midstream basically? Any help would be appreciated. Thank You.
B&DGurnee,
Nepreme coupling...check Home Depot or Lowes, you also may have to use a PVC reducer depending on your hose size.
P.S. These do have metal clamps on them
Good Luck!
Good Luck!
