Drywall ceiling access panels
What's a good way to make access panels in a drywall ceiling? I was considering using window casing and just letting the drywall rest on the frame made from the casing. Any other method that would be better?
There are quote a few access panels designed exactly for this purpose. Search the forum for access panels and you'll find quote a few links to the companies that make them.
Depending on the size of the access you need, another very good option is to put in a 3-gang drywall ring in the drywall. Then use a blank electrical switchp plate to cover it. The 3-gang drywall rings should be available at most home centers. If not, you can find them at electrical supply stores.
For larger areas, you can buy plastic access panels at home improvement centers. You just cut the appropriate size hole in the drywall and clip the panel in. These come in 8"x8" and larger sizes.
