Basement do-over
Basement do-over
My basement with poured foundation walls is currently semi-finished, which was done before I bought the house. The basement is dry, never had any water probs (only exception is when a pipe burst-ugh). Among other things, I want to add insulation to the exterior walls. Currently the walls are sheetrocked. Under the sheetrock is styrofoam insulation, approx 1" thick. I believe that insulation is pretty much useless. I have 2 questions, the first regarding the insulation. Can I put up a new wall and insulation, without removing the old wall???
Second question involves the ceiling. Currently it has a drop ceiling, with no insulation. The noise from the basement carries right up to the upper level. Since there is a lot of plumbing and electrical in the joists above, I am wanting to stay away from sheetrocking. I was thinking of insulation between the joists, and going with an acoustical drop ceiling. Good idea? Bad idea?
Any advice would be greatly appreciated.
Yes, you can do both. It is your basement, and you can make this as big a project as you like. Strip the walls and start over.
That is what I would do. However, you will have to take down the dropped ceiling. When the walls are done, insulate between the joists and re-install you new dropped ceiling. Do not lay your insulation on your dropped ceiling. Good Luck
Thanks for the info Jack. I know I have to staple the insulation to the floor joists, and not lay it on the drop ceiling. I also know that I have to remove the old drop ceiling. Just 1 question on the wall. I would like to avoid taking down the old sheetrock walls, as disposal would be a pain. Is it a real bad thing if I leave the old wall behind the new wall? Or is there an advantage to taking down the old wall?
Thanks again!
Thanks again!
