How did this pass code?
My house is a little over 2 years old. The basement is framed for several rooms. I noticed that all the bottom plates that touch concrete are pressure treeted lumber. There is one stud that is nailed to the concrete wall, that is not pressure treated...at least that's the way it looks to me. How in the world did they get away with that? Is there a minimum amount of wood that can touch concrete? I think that I will move this stud before I close the wall up. Any opinions/suggestions?
Thanks
Thanks
do these walls sit on the concrete slab (floor). do they hold up the joists for the main floor?
the only wood that has to be pressure treated is the plates for all bearing walls and the wood frame for the windows.
well thats our code in BC, Canada anyway.
Yes...all the walls in the basement are on a concrete slab. No...this wall does not hold up the joists...no it is not a load baring wall...but why would that make a difference?
Well...I think to be on the safe side, I will replace it.
Thanks.
Thanks.
Thanks.
I guess it depends if there is a vapour barrier between the dirt and the wood (usuall poly under the slab). In this case there may be a vapour barrier on the outside of the concrete wall?
but now that I think about it more. you probly should replace it.
