basement window
Old 05-09-03, 08:36 AM
msingla
basement window
Hello ,
I have one more question.
I have three windows in basement of size 32'' by 15''.
While I am framing the walls. How should I frame the window.
My layman thought process says :
I mean just a border of 2x4 would be okay and then drywall it with a little small hole to make it look better and then probably add a trim around it just like a door .
Please advice.
Thanks again.
Old 05-09-03, 09:21 AM
talon2112
The way I'm doing mine, and the way I've seen suggested the most:
Frame with 2x4's around the window up to the the edge of the surrounding metal frame. In other words, where the concrete/brick ends.
Don't drywall around the window, but use a stained wood trim around the outside of the window.
