Leaking Patio Door - Walk out Basement
Old 05-12-03, 05:42 AM
hz6k3w
I am finishing a walk out basement. The outside wall was finished with windows and a patio door. To finish the ceiling I need to put a box around some pipes just above the patio doors. I attached a box made with 2x4s to the finshed ( dry wall ) area above the door and the ceiling. The door is leaking, now. Did I damage some flashing above the door?
Thanks,
Roger
Old 05-13-03, 11:30 AM
Doug Aleshire's Avatar
Roger,
I doubt it but I would check on what you nailed! You didn't put a nail or screw through a water pipe did you? It might be a small leak that might have developed after you did your work. If this didn't leak before, I doubt it is a flashing issue but check everything.
Good Luck!
