outside or inside
outside or inside
Thank you for your advice and it was very helpful. The follow up question I have is regarding wether I need to do the inside of my basement as Doug suggest and do the same outside? Would the inside work be sufficent? I also wanted to ask 2 more questions: 1) How do I determine where to install the sump pump and do I need to have a slight incline on the pipe hearding toward the sump pump?
2) If I need to do work on the outside can you explain how that is done as well as how do I determine where the pipe should head too, meaning where it drains too.
I appreciate your help, thank you very much
Gordon Loop
Gordon Loop
Gordon Loop,
This should do it...
http://www.dspinspections.com/basementwater.htm
http://www.jlcnet.com/banner/basep4.html
http://www.usinspect.com/Crawlspace/PerforatedPipe.asp
Hope it helps!
Hope it helps!
