Floor and Wall Finishing Paint
Old 07-16-03, 09:10 AM
Is it recommended to paint the concrete walls/floor of a basement before finishing it? If so, what is the best type of paint/sealer to apply?
I talked with someone at a home improvement store and they said to use Drylok on the walls and to use a standard latex paint on the floor. Is he correct?
Added:
Would a poly vapor barrier still need to be used in this situation?
Old 07-16-03, 05:32 PM
Doug Aleshire's Avatar
ShaneK,
Try this...
http://drylock.com/H2Dry.html
Unsure why you want to paint the floor and if you are having moisture issues now, correct them the right way. Paints do not resolve issues that are more serious. Normally, no painting is required on walls or floors. This will be an issue that you have to decide.
Regarding the poly, read this...
Doing the wall framing 16" O.C. provides a solid base for your 1/2" drywall. If using traditional framing method, frame your new wall 1" from the vertical block/masonry surface if using R-13. The reason to keep the wood out from the walls is the moisture that could damage them. If using insulation like R-19 and only 2x4 studs, the insulation would touch the walls. I have stated before that if a homeowner did put thicker insulation in, and the wall was only 1" from the masonry surface, I have recommended hanging a vapor barrier between the back of the wall and masonry surface. This doesn't allow for the insulation to touch the wall and air movement is not restricted but at least you won't create damage to the insulation or wood.
Vapor barrier should be placed directly under the drywall. The warm inside air containing water vapor can get past the wall finish and insulation and condense inside the colder wall cavity. If enough of this happens, and the water cannot escape, wood rot, mold, and other moisture-related problems are likely to occur. For this reason, building codes often require installing a vapor diffusion retarder on the warmest side of the wall cavity.
This is what is required in Minnesota when using FURRING STRIPS;
"A 4 mill poly vapor barrier must be placed against all concrete or block exterior foundation walls prior to applying FURRING strips for full height of the wall. Another 4 mill poly vapor barrier must be placed over furring strips and insulation prior to covering with finish materials. (State Energy Code Requirement)" - MINNESOTA CODE
***PLEASE NOTE THAT YOU MUST MAKE SMALL SLICES AT GRADE LEVEL ONLY FOR WEEPING IN THE POLY IF POLY IS PLACED AGAINST THE BLOCK - ATTACH THE POLY WITH STAPLES TO YOUR JOISTS/FOUNDATION SILL PLATE***
If you do want to increase the R value, move the wall out further or use the R-13 and then apply a rigid insulation over the studs (warm side) then drywall (not paneling) *Code advises a 15 minute fire rated material over any rigid insulation - 1/2" Drywall*..
Kraft Faced insulation is fine to use in the above scenario. No need for the poly and you can do everything easily. You may find this easier and I would do this versus unfaced and vapor barrier because I don't like to play with it any more than I have to.
Just a note, when you use NON-W/T stock as the 2x2's or 1x3's as furring strips, you have to place a vapor barrier between that and the block wall - you have to attached the furring strips to wall somehow, right? You can't adhesively apply them, you have to use a ramset - this obviously has drawbacks...you just put a hole through the poly making it useless which in turn starts the problem with moisture touching the wood. Second, is if you used W/T or Non-W/T stock and have a waterproofing sealer on your block walls, you just penetrated the block, puncturing the seal coating that was suppose to stop water/moisture...creating possibly a worse problem....water that fills the concrete block cores starts to drain out or will leak in heavy rains. Just thought I'd bring this up. I would do 2x4 walls with R-11 or R-13, insulation would cost about $.02-$.03 more per square foot than the white foam and be better all around. Leave the walls out 1" from the block when framing, apply your poly over the studs apply the drywall and be done. You'll have no problems then.
Painting the walls is not a guarantee that no water will infiltrate, it also means that there still will be a cold void where warm air is trying to escape, thus the void will have temp change, enough to cause condensation but not enough to cause damage if you are protecting your insulation and wood. W/T bottom plates should be used on your walls. Applying the poly will protect wood and insulation for you.
Hope this helps!
