Basement windows
Old 07-28-03, 04:46 AM
Plazek
Basement windows
We are finishing a basement that currently has very high glass block windows. I would like to create the illusion of larger windows somehow. What would be the best method for doing this?
Old 07-28-03, 06:12 AM
C
Often, contrasting colors are the key to appearance. You might try painting the trim around the windows a white color with the darker surrrounding walls. If there is no trim, then painting white around the windows in the same fashion will help them look larger. Hanging curtains that are larger than the window will make the illusion of greater size.
HTH
