drywalling under stairway
Old 09-15-03, 06:01 PM
U
Received 1 Upvote on 1 Post
Hi-
I'm finishing my basement and my village requires me to drywall under the staircase leading down to the basement. Before, it was just a stairway leading down with 2 x 4's framed underneath by the builder.
If I drywall this area under the stairway soley to meet code (there will be no door, just an big drywalled empty area under the stairs with a large opening) and I use it for storage (empty boxes, personal items, etc.), am I required to run wire/conduit under there and put a light in? The area AROUND the newly drywalled understairwell will be lighted as that is where the furnace and utility box is.
Thanks,
Steve
Old 09-15-03, 06:36 PM
If there is no equipment that requires maintenance, then no light is required. I guess you already know that you need to use 5/8" Type X drywall, and that you need to tape it with at least one coat of mud.
Old 09-15-03, 06:55 PM
U
thanks!
John-
That's what I thought but wanted to make sure. And yes I have put up 5/8" drywall and a layer of mud, but thanks for checking. Always check for stuff like that when you see my posts please : )
Thanks for you time.
