boxing a basement window??
Old 11-10-03, 08:43 AM
zig
soon enough i am going to start working on my basement. there is drywall up on most walls. i am going to start in a small storage room. but i want to box the window in. right now the drywall goes up to the opening. i want to drywall the angle going up to it around. what is the best way?? i saw it in a friends house, his was already done when he bought it, but it looked good. do i glue wood then drywall to the cement?? or what??
thanks... i can get a picture if it will help...
Old 11-10-03, 09:37 AM
coops28's Avatar
If I'm picturing this right then you have a wall framed. Hopefully you put a stud flush with the edges of your window and one flush on bottom and top as well. Then you can slide a piece of drywall back to your window on all four sides. Put a little adhesive on the back to part of the sheetrock to attach to foundation and screw the front to the wall stud creating an outside corner. Finish with corner bead. Depending on how good your cut was you will either have to flat tape the back against the window or just caulk. Make sure to caulk either way.
Old 11-10-03, 09:40 AM
zig
the walls were already up when i bought the house. just purchased in july... so i'm a first time homeowner and enjoying it...
yes the wall stud is built right up to the window. the only problem is that the foundation angles up towards the window to let more light in. i'll have to play with some drywall and see how it will work. i can snap a picture tonight... i have at least 4 windows i will be doing...
thanks...
Old 11-23-03, 07:38 PM
B
Don't mean to barge in here...but...I have a similar situation. I am wondering if I could just finish my basement windows by installing 4 peices of drywall on the edges, and use corner bead...but what about trim? Can I miter 4 peices of trim and put together around the window...kind of like a picture frame? Will that look ok? No window sil? Trying to keep the cost down...and ease of installtion to a minimum as well.
Thanks.
Old 11-28-03, 12:54 PM
mark8076
I know what you guys mean about the concrete sloping toward the window. I finished one room in my basement right after my house was built 2 years ago. I framed in around and ran the drywall in to butt into the window frame. I did not slope the drywall, I nailed it to the wood framing and glued it to the concrete right adjacent to the window frame. I HAVE HAD PROBLEMS. Even though the windows are insulated glass and vinyl frames they do develop a bit of condensation in very cold weather. This has worked it's way into the edge of the drywall. Also, in a driving rain storm I had a bit of leakage around the window. This has caused water stains on the drywall.
I am now finishing the rest of my basement. I am boxing the windows with exterior grade plywood, primed and painted. I am going to then trim them with some door casing.
