French drain
French drain
How does one go about finishing a basement with a floating
floor ( French drain construction ) ? There's about a 2" clearance
around the whole perimeter.
loco,
Below is a general format that I have written,
I guess this is the best and most economical way to construct walls that would be placed on the exterior. I prefer to see 2x4 but as mentioned by others they can get 2x3's. You still need that W/T BOTTOM PLATE. The best way is to attach WOOD TREATED BOTTOM PLATE to the concrete is to use either...
Concrete nails - Sometimes this is hard and time consuming!
Tapcon Screws - Relatively easy but again time consuming!
Hilti Gun with ramset nails - Rent the gun, buy nails and charges - Very fast and holds great! - No adhesive is needed.
Doing the wall framing 16" O.C. provides a solid base for your 1/2" drywall. If using traditional framing method, frame your new wall 1" or more inches from the vertical block/masonry surface if using R-13. In your case, you need more room due to the french drain. The reason to keep the wood out from the walls is the moisture that could damage them. If using insulation like R-19 and only 2x4 studs, the insulation would touch the walls. I have stated before that if a homeowner did put thicker insulation in, and the wall was only 1" from the masonry surface, I have recommended hanging a vapor barrier between the back of the wall and masonry surface. This doesn't allow for the insulation to touch the wall and air movement is not restricted but at least you won't create damage to the insulation or wood.
Vapor barrier should be placed directly under the drywall. The warm inside air containing water vapor can get past the wall finish and insulation and condense inside the colder wall cavity. If enough of this happens, and the water cannot escape, wood rot, mold, and other moisture-related problems are likely to occur. For this reason, building codes often require installing a vapor diffusion retarder on the warmest side of the wall cavity.
If you do want to increase the R value, move the wall out further or use the R-13 and then apply a rigid insulation over the studs (warm side) then drywall (not paneling) *Code advises a 15 minute fire rated material over any rigid insulation - 1/2" Drywall*..
Kraft Faced insulation is fine to use in the above scenario. No need for the poly and you can do everything easily. You may find this easier and I would do this versus unfaced and vapor barrier because I don't like to play with it any more than I have to.
W/T is wood treated. International Residential Building Code says "it must be used whenever wood is in contact with concrete and/or masonry". Check it out with your local inspector.
Hope this helps!
Hope this helps!
Loco, you used the term "floating floor". Are you talking about the system of building walls using spikes and two separated bottom plates that allows the floor to freely move up and down when the soil below it expands and contracts? This type of construction is common in areas of expansive soils. If this is not what you're talking about, then ignore my post.
