Lowering basement.
Old 11-21-03, 10:38 PM
illectric
Lowering basement.
Im not an expert at all on anything in this field but believe that it is possible to do most stuff on your own with help of course. I have no clue where to begin other then the basement needs to be lowered and extended. What preliminay steps do you guys suggest for planning this type of job? I would like to go as low as i can and extend as far as possible to maximize space. Any good links to under pinning instructions?
Old 11-22-03, 04:43 AM
awesomedell's Avatar
illectric,
Hello & welcome to the forums.
What exactly are you wanting to do? Have you just got like a crawl space that you want to open up into a full basement? Post back with some detail & I'm sure there's someone around here that can give you some pointers.
Old 11-22-03, 10:10 AM
illectric
some specs
Thanks for the reply. The basement is just over 6' high. I would like to dig it deeper at least a foot, well actually as deep as it can go. I want to maximize the basement with as much room as i can. I cant make it any wider due to being inbetween two other houses but would like to extend it both to the front and the back. In the back there is an addition but underneath was never dug out. Thats one side where more room can be added. The front is flush with the rest of the house but i would like to go further out and on top of what i dig out will go a porch/enclosed veranda something like that. Lookin for some steps to start out.
Old 11-22-03, 11:05 AM
Received 1 Upvote on 1 Post
The important thing is not to undermine your footings. If you dig below your footings, you must stay at least as far away from them as the distance you excavate below them. I think a couple hundred bucks paid for on-site consulting from a structural engineer will be well worth the price. It's such a downer when your house collapses.
You also obviously want to stay above the water table. And it will be difficult to go below the bedrock level.
Old 11-22-03, 12:32 PM
Ed Imeduc's Avatar
Lightbulb Dig out
I think You should check on the code there before you dig. Like john said there is code for digging close to the footing. I know there is one here. ED
Old 11-23-03, 04:58 AM
I agree with the other posters here, definitely get a qualified local guy to come in and evaluate the project, must say you certainly sound ambitious, digging out a foot over an entire basement by hand? Couldn't even imagine it!
