How can I approach this project?
Old 12-09-03, 12:44 PM
yvonnedono
I have an unfinished basement (cement floors and insulation of walls shows). It is a walk out basement (meaning one wall has windows). I want to turn the basement into a photography studio so I need to be able to cover the wall (that has the windows/door) with a curtain. I'd like to be able to slide the heavy white/black material across that wall when I need it, and then slide it away when not needed. So, I guess, I would need to be able to slide the curtain along the wall, and then make a turn to slide along another wall. In fact, I'd even like to slide it across the basement to hide exercise equipment etc., when needed.
Any ideas? I"m trying to do this cheap, cheap cheap
thanx for any input
Old 12-10-03, 07:29 AM
brickeyee
Cheap would be multiple travers curtain rods with multiple panels. Most rods to turn corners are not inexpensive, not are large traverse rods. Two rods that each cover half may be less expensive than a single oversize unit.
