vapor barrier - best practices
Any recommendations to hold vapor barrier against basement walls (cinder block).
No... when building the wall 4" away from the foundation, whats the best to hold the vapor barrier up?
(several walls are coming in because of pipes) and the rest are an inch or two in because of the water channels in the floor. (that lead everything to the sump)
This is a common question here - please refer to the following thread - some great ideas are discussed:
http://forum.doityourself.com/showth...hreadid=150877
I don't want to start an argument about this but adding a sheet of plastic to a concrete basement wall doesn't sound like a very good idea to me. Simply for the fact that the plastic will sweat against the concrete and I'd be concerned about growing mold and fungus and wild things in there. I'd be more prone to use a nice waterproof paint or Styrofoam if I thought there was any need for it. Otherwise use the vapor barrier on the stick built wall and let it go at that. Just my 2 cents.
I agree with webrebel, I just don't think the 2 layers of poly (one against the masonry wall and one under the drywall) is a good idea, but here it's a code requirement. It goes against everything I was ever taught about double vapor barriers. I guess time will tell if this is a good idea or not.
In the meantime, we have do do what code requires.
Bruce
Bruce
Hehe, i didn't know it was such a hot topic. I appreciate everyones input though!
I treated the walls with the sealent, so i'm asking if that will suffice for vapor barrier.
Like pulling teeth to get answers over the phone!
If you treated the walls with the sealant, IMO you'll be fine. Here in the midwest, we finish basements all the time using faced batted insulation along new exterior walls, no poly at all & to date I've never had a problem. But we don't have to deal with strict bldg codes except in a few areas.
There's my $.02, worth the price charged.
