Finishing my basement with panel board
Old 01-04-04, 11:10 AM
jeffgeorge
I am about to start finishing my basement, and am considering using just panel board instead of drywalling it first. Is this feasable or should i drywall first?
Thanks for any help.
Old 01-18-04, 06:53 PM
R
Panel board alone, over studs will be very flimsy. If this is an are you are going to use on a regular basis, I suggest you sheetrock first.
Old 01-19-04, 10:31 AM
coops28's Avatar
Then if you sheetrock first, in my opinion, just go ahead and finish the sheetrock. It will look a lot better. You need to check with you local code. Some codes will demand drywall under paneling some don't.
Old 01-19-04, 12:10 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
If you have a good panel board We put it right on the studs. If its a dark panel at the seams we take a spray can of black or dark paint and go down the stude with it. This way if the panel pulls apart you dont see the white stud. ED
