Insulating for noise
Old 02-02-04, 11:48 AM
A
Question Insulating for noise
I am in the process of refinishing my basement and would like to insulate the "furnace room" to prevent hearing the furnace turn on/off. The room is a combination furnace room and storage area and is approximately 160 sq. ft. with 2X3 construction. I would only like to insulate the interior walls. Is there any safety issue with this?
Old 02-02-04, 02:12 PM
Dave_D1945's Avatar
Received 1 Upvote on 1 Post
Shouldn't be any problem. Since it's interior walls, you could use unfaced batts
Old 02-12-04, 05:14 PM
A
Thanks, my only concern was that it was that one of the walls is about 3 ft. from the rear of the furnace.
Old 02-12-04, 07:07 PM
Doug Aleshire's Avatar
afiorillo1,
The fix is to add drywall to this, firetape only.
Old 02-12-04, 07:20 PM
When in doubt, check the furnace installation specifications. Most furnaces are zero-clearance in the rear, which means that there is no heat problem there. Fiberglass is very fire resistant anyway. Unfortunately, insulation does a better job on high frequency sound than low frequency sound, and furnace noise is pretty low frequency.
Old 02-15-04, 11:47 AM
awesomedell's Avatar
If the inside of that wall is already got drywall on it, I'd agree with Doug, just add another layer of drywall & fire tape it.
