wet basement
Old 02-11-04, 12:30 PM
harless
wet basement
i have apainted floor that is getting water up through the painted cement floor is their any sealer that i can apply over the paint
Old 02-11-04, 01:10 PM
I
Sealer will not stop the water from penetrating through the cement. You need to apply Hidraulic Cement on the cracks.
Once it is dry- you can use a sealer.
Old 02-13-04, 10:02 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Id look out siad and see if you can find where the water is comeing from. Gutter all good and drain away from the home. Does the ground slop away????ED
