Humidistat Test
Old 03-08-04, 11:01 AM
bluejay168
Humidistat Test
I bought a 45 pint dehumidifier from Sears and am suspecting there is problem in the auto control of humidity because the machine is always on even I set the humidity setting to 70%, which is the highest setting possible. I have a very small basement, and even in the winter it never stopped. How could I test if the humidistat is working or not? or it's just too much moisture? Thanks for your response.
Old 03-08-04, 11:35 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Take it up stairs and see if it will shut off. Or there are humidity indicators you can buy. Also you could get a Sling psychrometer, this can tell you what the humidity is. Boy in the winter it just dont seem like you could have a 70% humidity in the home with the furnace on .ED
