Concrete over basement windows?
New Member
Moved into a 1900 farm house. Most of the basement is quite dry, but there is one room which has a dirt floor that is somewhat damp. The foundation is cracked and heaved in that room, obviously due to a window which is below grade and will collect water.
I have never had a basement before and need some other thoughts on what to do.
Please explain the pros and cons of the following ideas:
1. Remove and concrete over the window opening, then properly fill and grade soil around foundation. There are plenty of other windows, and basement is a walk-out, so egress shouldn't be an issue.
2. Put in a window well, leave the window as is, and try to re-grade the soil.
I don't care about light in that particular room - it will eventually be a well lighted workshop
Received 1 Upvote
1 Post
As you say this is a walkout Id go for #1.
Block and close the window off with cement. Then rework the ground for a good slope away from the home there. That old a home I sure would check all the gutters and make sure they get the water away from the home also. like pipe out the downspouts away from the home about 10'
ED
ED
