Attic Slope Roof Insulation - behind knee wall
Old 05-01-04, 04:53 AM
joemcc
Smile Attic Slope Roof Insulation - behind knee wall
I'm finishing off my attic and am about to insulate the attic roof (slope roof). I'm wondering if I should put the insulation all the way down to the eaves (which will require about 4 feet of insultion once I get past the knee walls). I'm wondering this because I am going to put insulatin behind the vertical knee wall also.
Is it better to put insulation on the slope roof all the way down to the eaves and insulate behind the knee wall?
Thanks!
Joe
Old 05-01-04, 07:05 PM
R
http://www.urbanoptions.org/pages/insgraph.htm#attics
There are some graphics under "Kneewalls and Slopewalls" that may interest you.
Old 05-02-04, 05:05 AM
joemcc
Thanks for the website. This site did help, but I did not find the answer the my question above, which is:
If I'm putting insulation in my knee wall, is it better to insulate the roof (slope wall all the way down to the eaves or should I stop insulating the slope wall once I hit the knee wall?
There was one graphic that looked as though it put insulation at the knee wall and the floor behind the knee wall, but not the slope wall behind the knee wall. It did not have any text about this, though... I'm only guessing that that's what it is indicating to do.
Thoughts?
Thanks!
Old 05-02-04, 01:15 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Id say stop . On that slope wall that is part of the ceiling of the room there you should have foam rafter vents so the insulation dont touch the roof. Then down the knee wall to the rafter below then across in the rafters to the out side plate. With a foam rafter vent so air can get in there from the vents in the over hang .
ED
Old 05-02-04, 02:49 PM
joemcc
Smile
Ed,
I need some clarification.
This is what I heard you say:
1) Install the insulation on the slope wall from the ridge vent down to the knee wall.
2) Then run the insulation behind the knee wall (vertical) to the floor.
3) Install foam rafter vent on the slope wall from the ridge vent to the knee wall and then continue the foam rafter vent on the slope wall past the knee wall all the way to the vents in the overhang.
Is this right?
Should I install the rafter vents all the way down to the vents in the overhang but only install the insulation on the slope wall to the knee wall?
Thanks so much for your help. I think this is what you said in your last note, but I am not sure.
Thanks again!
Joe
Old 05-02-04, 03:54 PM
Ed Imeduc's Avatar
Wink
With the foam rafter vents so the insulation dont touch the roof.
YES
same as in #1
You only need that foam vent in the rafters there right at the outside plate.Or where the roof and ceilings rafters meet. So air can get in there from the vent holes in the overhang of the home over the ceiling insulation and over to the knee wall.
ED
