Finishing Basement questions
I am finishing half of my basement and leaving the rest unfinished for laundry and storage....the height of the ceiling is only 6'4'' ... do i drywall the ceiling? what options do i have? i also am not sure about the floor...it is concrete and i don't want to lose any height with a subfloor...can i use laminate? what kinds of weather/moisture barriers do i need? thanks
Is it 6'4" all over the place? First thing I'd do in your case is make sure your local code is okay with this. That is if you need a permit
If you don't, go ahead and finish it with drywall (minimum height loss) and no subloor, just carpet over concrete. It'd be a good place for kids
Good luck.
