Removing Old Tiles From Basement Floor
Old 08-30-04, 05:34 PM
Howard Loveless
Question Removing Old Tiles From Basement Floor
Don't know if they are asbestos or vinyl but they are attached to the concrete - how do I best remove them to prepare the floor for something new/better?
Old 08-30-04, 11:50 PM
Just install over them.
Old 08-31-04, 07:03 AM
Howard Loveless
Question Removing Tiles In Basement?
We considered putting a new floor over them - but in some areas the tiles are already missing, so there is uneveness and there has been some moisture in the basement and I want to tear out all the old smelly stuff, not just cover it up. So - anybody else have a suggestion?
Old 08-31-04, 09:55 AM
farmall
Couple of things I have used are a flat spade, scraper and a floor scraper (big blade long handle).
Old 08-31-04, 10:38 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Home depot and lowes both have them work good
ED
Old 08-31-04, 01:27 PM
When you remove the tile, the adhesive may also contain asbestos.
First you will need to determine if this is a "true" cut back adhesive. A true "cut back", is made from asphaltic material, is not water sensitive, and will not soften when exposed to water.
Test a small section with hot water, if it softens and becomes easily scraped for removal, then thats what you use. If not, a removal media will be required.
Here are links that might be useful:
http://www.onthehouse.com/
http://www.citrusdepot.biz/docs/citr...ic_remover.pdf
