Attic question
Old 11-26-04, 12:35 PM
tuchy
Attic question
I am renting a 2 bedroom upper of a duplex and am experiencing drafts from both bedrooms. Can you suggest anything than insulating that would prevent those drafts. There is a opening in the one bedroom in the ceiling. Any suggestions would be appreciated. Thank you
Old 11-26-04, 12:48 PM
Ed Imeduc's Avatar
Wink
Not sure what you have there . What happen when you block off that grill you spoke of
ED
Old 11-30-04, 05:21 PM
A
The opening in the bedroom ceiling I am assuming is meant to be an attic access. If so, you can place some BAT insulation on top of it, and then seal the joints around the cover with a removable caulk, e.g. Peal & Seal.
Where is the draft coming from in the other bedroom? If the drafts are coming in around the windows, you might also consider Peal & Seal here.
I am not sure what grill Ed was referencing.
