Room in basement
Old 12-25-04, 06:55 AM
Davejb's Avatar
Room in basement
I want to build a gameroom in my basement. Biggest issue is an unlevel floor. The room is going to be about 15x20 or so. My plan was to use pressure treated 2x4's to create a bottom plate, then use some self leveling concrete to make the floor even for a fooseball and pool table, then frame the walls and create the room. Is this the best way or am I off the mark?
Old 01-03-05, 09:31 PM
darren_1974
Sounds like it would work just fine. Be sure you leave enough of the bottom plate exposed so you have something to screw your drywall to.
Old 01-04-05, 05:16 AM
Davejb's Avatar
I plan on nailing a 2nd bottom plate of non PT on top of the PT after the floor is leveled to make sure I have room for the drywall. Would the leveler cause the PT to rot after a while?
Old 01-04-05, 05:25 AM
darren_1974
no more than the concrete thats already there
