Replace Collar Ties With Gussets?
Old 01-03-05, 08:34 PM
Dagst47
Hi-
My house was built in '22 and is "non-standard" construction for a very typical 20x20 two story cabin style home in Western PA. I'm interested in making the attic space useable- is has never had any access or ventilation (*yes*, completely sealed off!). While remodeling a closet, I decided to go through the ceiling to check it out:
I found standard rafter roof construction with lots of space, but the ceiling joists run perpendicular to the rafters. There are 2x4 collar ties about 3 feet down from the peak, connecting every other rafter pair. Can I replace these with gussets at the peak to make some headroom? There appear to be no "functional" rafter ties in place (ie: nothing in the lower 33% of attic space connecting rafters).
Besides converting the attic to living space, the other option is to just insulate, ventilate, put in access and use it for storage. I should mention that I'm aiming for maximizing resale value, as this is not my "final solution" for a house. Any input/advice would be much appreciated.
Thanks!
Doug
e-mail addresses not allowed in posts
Old 01-19-05, 01:34 PM
Ed Imeduc's Avatar
Wink
No I would not try and take the collar ties out there for sure . Yes they do a lot. Vent it real good Put a R 30 or better in it and just store stuff up there.
my .02 cents
ED
