Fireblocking around flexible HVAC ducts
Old 01-18-05, 12:59 PM
P
Any suggestions on how to fireblock around flexible ducting? Here is my situation.
My basement has it's own forced air heatpump system. The HVAC contractor ran a number of small diameter (6-8") flexible ducts to each of the registers. Since the ducts run perpendicular to the ceiling joist, they are hung with straps below the joists. I am going to put a suspended ceiling just below the ducts.
I framed a utility room around the air handler. The ducts are perpendicular to the utility room wall and run just under the top plate. I put blocking between the studs just below the ducts. I can drywall up to the blocking beneath the duct which will be the approximate height of the ceiling.
My understanding is that I need fireblocking between the utility room and the space above the syspended ceiling. I need to figure out how to fill the voids between the round ducts and the square opening between the studs and blocking. Since the flex ducts crush and move easily, I am not sure what would work best. Thanks.
Old 01-26-05, 09:03 PM
PaulV,
it seems it might be easiest to use 5/8 sheetrock up to the first floor deck. First remove the ducts. install the sheetrock. cut round openings/ pass through the flex ducts or cut the flexible ducts and pass through solid sections and connect ducts..
