Finishing around basement windows
Old 01-24-05, 06:53 AM
O
Good morning all.
I have a ranch style with a poured wall basement. The windows in the basement are the standard Andersen utility awning style that are very commonly used.
I am finishing a room to be used as an office in an area where one of these windows exists.
I framed the walls. (full 2x4)
Insulated with fiberglass insulation.
applied vapor barrier.
drywalled.
As I get to the point of finishing around this window I'm not sure what to do. Since I live in a northern climate, there will at times be some condensation that will build up on the inside of the window.
Do I totally seal the sill with caulk and let any moisture puddle there? Should I leave a small gap to allow any moisture seep down between the framing and foundation?
Thank you all in advance for any and all help.
Dan M.
Old 01-24-05, 07:49 AM
don't leave a gap
Go with plan A. I doubt you'll get any "puddling", but even if you do get some condensation there, it'll have a better chance of drying out than it would behind the wall.
BTW, how are you finishing the window, drywall or wood?
Old 01-24-05, 07:59 AM
O
Well I'm still a bit undecided on the finished material. I'm leaning toward wood though.
My thought with wood is to paint it with a good enamel for durability.
What are your thoughts about slightly "tilting" the sill in toward the room?
Thanks for your help.
Dan
Old 01-24-05, 08:33 AM
Dan
Great idea, if you don't mind that look. I finished my basement window trim/sill with 3 layers of polyurethane (back side too) for the natural wood feel. Holds up just fine.
Old 01-24-05, 08:39 AM
O
To allow the moisture to "run off". Keep in mind, these are uninsulated windows so there will be condensation.
Of course I know the down side is that it will probably stain the drywall.
