Foundation vents
foundation vents
Foundation vents are used to ventilate a crawl space. While I have seen
crawlspaces with windows, it's a bit unusual, as they don't serve any good
purpose. If an access is needed, a removeable hatch cover is more practical.
If we are talking about a crawlspace foundation, the vents they sell for this
purpose are the same size as a concrete block. Assuming you have a block
foundation, here's some hints. You can remove a top block to make room
for the vent, but it shouldn't be under a floor joist and it shouldn't be under
the butt-ends of the sill-plate on top of the blocks. If you can't avoid these
scenarios, go ahead and remove the block, while temporarily supporting the
joist or sill in question and install a new block (the old one always breaks)
laid on it's side (with the web cords horizontal) and leave it sticking out
into the crawl space enough to allow a vent-sized recess on the ouside
in which to install the vent. Oh, one more no-no, don't remove one of the
blocks that has the anchor bolt imbedded in it, it has a definite purpose.
