Ridge Vents on a one-sided roof
Old 03-18-05, 09:23 AM
yfct
Hi, one of my rooms on the second floor doesn't have attic and is by itself on that side of the house. The roof only have one side so the ceiling is a slope with a low point and a high point. I notice the soffit has soffit vents but is partly covered with paint. Don't know whether there is exhaust vents at the high point of the roof. Assuming not, can a ridge vents be used in this structure? If so, do I just cut a small opening along the high point and cover it with the regular ridge vents followed by the ridge cap (is modification of the ridge cap necessary to fit the shape??)? Any other suggestions? Also, how do I go about removing the paint on the soffit vents? Or is it better off to replace the soffit vents completely?
Thanks!
Old 03-18-05, 01:29 PM
Ed Imeduc's Avatar
Wink
Id say you have a lot of ifs here. What is the pitch on the roof? Does it stop at a wall like?. What is the insulation up in the rafters now. Does it touch the plywood roof there? you have to have it so air gets over the insulation
Yes I take and cut in new vents in the over hang. Id use the 3"strip like kind. to let air in to all the rafters.
ED
Old 03-21-05, 07:09 AM
yfct
Ed, Thanks for the response! Yes, the pitch of the roof stops at the top of a wall. Since there is no attic space, what's the usual way to check out the insulation in there? In any case, some sort of vents should be installed for this kind of structure, right??
Old 03-21-05, 08:05 AM
Ed Imeduc's Avatar
Wink
You need vents there. Can you take down some of the over hang where the vents are now and look up in there to see what you have. Are cut into the drywall there to see.
ED
Old 03-21-05, 10:55 AM
yfct
Will check it out. Thanks again Ed!
Old 03-24-05, 07:32 PM
ridge vents
The way I understand the description of this roof, a ridge vent won't work
because there is no ridge. A ridge vent at the highest point of this roof
surface would channel lots of rain water into the ceiling below. A ridge
vent has to have a certain slope downward on both sides of the vent.
Old 03-24-05, 08:01 PM
Doug Aleshire's Avatar
yfct,
Are you referring to this - roof to wall ventilation?
http://dougaphs.smugmug.com/gallery/364233/1/18176554
http://www.cor-a-vent.com/X-5.htm
Gaf Ventilation Products
http://www.gaf.com/General/GafMain.asp?Silo=RES1&WS=GAF
Hope this helps!
Old 04-01-05, 01:13 PM
yfct
Doug, These are cool websites!! Thank you very much!
Old 04-01-05, 04:13 PM
yfct,
You're very welcome!
I hope that you find what will be appropriate for your application.
Good Luck!
