Attic floor and loose-fill insulation
Old 05-31-05, 05:17 PM
thomasvt
I am planning to put in an attic floor. There is loose-fill insulation in the attic now. Not sure whether it is cellulose or fiberglass (it looks white like cotton)
Do I need to remove the loose-fill insulation, put in the insulation batts and then install the floor? Seems like a lot of work.
Old 05-31-05, 10:00 PM
Insulation
No need to remove old insulation unless it's moisture damaged. If it's still
nice and fluffy, I would just leave it there and put your floor boards right
over it. If your house is older, it probably is cotton, if newer it probably
is fiberglass.
