Egress Window
Egress Window
Hi all,
Does anyone have any idea how much the egress window cost in pa ?
I think we need to take permit but for that egress window is a must.Also,how much is the penalty for basement without pemit ?
Please reply...
thanks,
nikks
Please reply...
thanks,
nikks
The cost of an egress window depends upon its size and quality. Your local home center will have egress windows marked as meeting egrees standards. Egress windows must meet a minimum vertical and horizontal opening dimension as well as a minimum square footage. The requirements are designed to allow a fire fighter with air supply to fit through the opening.
Also please note that egress codes not only require a window that meets standards but establish the maxamum allowable hieght of the window sill above the floor (in remodels this can be met by providing a permanent step) and requirements for a window well if it is a daylight basement.
Check with your local jurisdiction for specifics.
DavidJ
DavidJ
Egress Window
An egress window is an absolute must if you are going to do any remodeling.
The extra cost is that of a slighlty larger window that you will enjoy more than a smaller window.
When you go to sell in the future, you may not be able to sell the home until you go through the cost of replacing a non-complying window. This is a big cost.
The egress window requirement will not go away.
Dick
Dick
There's also a requerement on the size of the window well (makes no sense to have the big window and no room in the window well to maneuver. And there may be a requirement for a fixed escape ladder.
Best advice is to go check with your bldg. dept/ inspector.
