basement window frame ideas
Old 03-09-06, 08:27 AM
I want to finish my basement window with an inclination in front so that I have easy access to opening the windows. Side view of the window will look like...
------------------- top
| window
/ inclined wall (concrete)
_ |
stud _ | wall (concrete block)
wall _ |
Old 03-09-06, 08:28 AM
got meesed up text.
Can sheetrock/plywood touch the concrete around the window or we need P/T wood?
Thanks
Old 03-09-06, 02:12 PM
chandler's Avatar
Received 2 Votes on 2 Posts
Are your windows already installed? If not, you should use pressure treated wood in contact with the block. If they are already installed it is a moot point. I would not place plywood nor sheetrock directly against concrete block.
