must smell in my house
Old 05-12-06, 12:50 PM
D
what can I do abiut it,is it mildew?
Old 05-12-06, 01:50 PM
D
Received 2 Upvotes on 2 Posts
If it's "musty" it's b/c there's too much moisture in there so open up some windows (and use fans if you have 'em) to rid the smell.
...then find what's the cause of all that moisture and correct the problem.
The smell is in the basement?
Old 05-22-06, 12:59 PM
waterproofing's Avatar
the solution is very simple...
checkout www.sanidrydehumidifier.com
as DIYaddict said... it's moisture...
by opening the windows and using the fans will get rid of the smell for now... but if you have moisture problem.. it will get smelly AGAIN...
so you might need to look into solving the problem permanently
good luck
Old 06-07-06, 09:28 AM
D
its in the basement and in the stairway to the basement
Old 06-07-06, 06:10 PM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
Do you have a dehumidifier?
Old 06-08-06, 09:08 AM
D
yes should i keep it on all day/night
Old 06-08-06, 01:48 PM
D
I am no pro nor have I ever used a dehumidifer, but doesn't it have a sensor or something? Does it turns off or something once it reaches that setpoint?
Old 06-08-06, 04:33 PM
Most of the new one's shut off at set point! Buy a chep RH meter 10-25$ and set the dehumidifier to shut down at 50% RH
