basement insulation
Old 09-30-06, 09:55 AM
L
basement insulation
1) Two of the rooms that I am framing are for storage and for the water heater/HVAC. Both of these rooms will reside on the outside wall and I am not planning on finishing the inside of these rooms. Should I install any kind of insulation or vapor barrier on the concrete walls or can I leave it as it?
2) Any tips on insulation and vapor barrier for a walk out basement wall that only has a concrete footing.
Old 09-30-06, 07:55 PM
chandler's Avatar
Received 5 Votes on 5 Posts
You could always glue up 3" solid foam on the walls, but remember, walls that are underground are geothermally stable, and the temperature will remain the same year round.
