Radon testing
Radon testing
Hello,
Live in Maryland and have not had my house tested for radon yet. Been here two years or so.
Can someone give me some guidance on testing for radon? Lots of information online and from "expert" neighbors but looking for some practical recommendations for testing procedures/products..
Thank you!!
Scott
Thank you!!
Scott
There Is Nothing To It
You just buy the little trap at whatever hardware store you desire. The directions are on the box. You just keep your basement as buttoned up as possible and put the little trap box into a dark corner somewhere with as little ventilation as possible. You mark the date and time and then retrieve it in the alloted time. You write the time and date on the box and return it in the prelabled return mailer. The company reads the amount of radon and compares it to the recommended values you should be exposed to. They e mail you the report in a week or so. If you have any of the various levels they recommend what to do to lower it to acceptable levels. Ask around everyone talks about it while very few bother. Cheap insurance against the second leading cause of lung cancer. It is also a good idea to do the test again every %^%$ years in case a pocket of gas has opened up in the meantime.
Wile I agree to put it in a basement you need to live your normal life! Opening windows, opening doors, running the heat, cleaning ETC. You are looking for normal readings so you need to do everything you normally do.
Some radon mitigation companies will send you a test kit for free in hopes you will use their services if your readings are high. The kit looks pretty cheesy - a cardboard envelope held open with a piece of foam, but it's standard. Ours was something like 0.2 pico curies over the "max" so we were able to get money at closing for a mitigation system. We did without for six years because we didn't use the basement that much, but now that our master BR is going down there, we had a mitigation system put in.
