Basement Toilet rough in mistake...
Old 01-26-08, 06:46 PM
I am adding a bathroom in the basement. The plumber and contractor met prior before the drain line was roughed in for the toilet... Wel of course, there is a miscommunication and the is only room for a 10 inch toilet... The wall is 10 and 3 quarters from the center drain... Instead of cutting up the slab, again, that would cost a mint, the plumber said he can install a 10 inch toilet. Are there any other options so
I can add a 12 inch? The wall can not be moved back any more... Can he add an offset flange? It is a 4 inch drain/pipe.
Old 01-28-08, 06:01 AM
Believe it or not, it's not that big a job to bust up the concrete and move the drain 2". It'd be a good saturday project for anyone not afraid to get their hands dirty. Just have to rent a jack hammer. You can probably be done with the whole thing in 2-3 hours.
Old 01-31-08, 02:10 PM
Well my plumber did it and it cost me a mint....
Old 01-31-08, 04:01 PM
michaelshortt's Avatar
Why hot use the 10 inch toilet?
Old 02-01-08, 05:33 AM
Does that surprise you?
Old 02-05-08, 09:27 AM
10 inch should be fine? Correct?
Old 02-05-08, 09:52 AM
10 inch will do fine.
