Mold in basement
Old 02-20-08, 09:23 AM
Mold in basement
What's the best way to remove mold from a basement wall? The wall is poured concrete & has been painted.
Also: powdery, white residue from floor cracks (leaching?) How do I remedy and repair.
Old 02-20-08, 07:03 PM
airman.1994's Avatar
Received 4 Votes on 4 Posts
Wet area with 10 parts water to 1 part bleach. Let sit about 10 minutes then wipe with a rag. The white effervescence will keep coming back unless you can fix the moisture problem.
Old 02-21-08, 07:15 AM
Thank you.
I think the moisture may be getting in this way: I had a concrete sidewalk installed along the exterior wall where I have the problem with the mold. The sidewalk is snug to the wall. Between the sidewalk and the basement wall, they put in an expansion joint.
Does it make any sense to remove this expansion joint material and fill with the pliable stuff they use around pools to allow for expansion and contraction due to freeze/thaw cycles?
