Concrete and Plastic adhesive!
Old 02-22-08, 04:20 PM
Taipans's Avatar
What is a good water proof adhesive to use between plastic and concrete?
Thanks
Old 02-23-08, 04:45 AM
chandler's Avatar
Received 2 Votes on 2 Posts
Oooh, sounds like a trick question. What type plastic and what is the item you want to stick to the concrete? Will it be installed vertical or horizontal? Is it in sheet form or smaller?
Old 02-23-08, 09:15 AM
Taipans's Avatar
I am suppose to be putting plastic sealed to the lower part of the wall then across the 1" gap for the parameter drain. This was instructed by my builder to eliminate any worries about vapor rising up through the crack in cold months.
I am going to buy the 3' x 50' roll of 4mil Polyethylene. Install along the parameter closing up the gap on only the finished part.
So it needs to stick Poly to foundation and floor concrete and be water resistant.
Thanks
