Sealing bathroom exhaust fan
Old 06-11-08, 04:54 AM
P
Hiya,
The last owner of my home cut a bigger whole for the upstairs bathroom exhaust fan and heat radiates into my home through the unsealed portion. What can I use to seal it up? I'm guessing that foam insulation out of a can?
Thanks!
Old 06-11-08, 05:56 AM
Received 291 Votes on 259 Posts
The foam will work but you need to be carefull - if it expands too much, you might damage the fan.
Does the fan not cover the entire hole? Would joint compound and tape make it look better?
Old 06-11-08, 06:24 AM
P
Thanks for the reply. Well the fan is enclosed within a box so the foam would probably OK as long as it is safe. the cut out isn't that much bigger and there is a grill on the ceiling of the bathroom so patching it up really wouldn't make a noticeable difference. I'd rather do the quick and dirty here as long as it's safe
Old 06-11-08, 06:52 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
use the DAP latex foam in a blue can, normally over near the caulk. Much better than the "great stuff"
Old 06-11-08, 07:01 AM
P
Will do thanks!
