how do I finish basement bath roughin hole
What do I do - if anything - to finish off the hole in the slab that the bathtub drain plumbing connects to. Presently it is a hole filled with pea gravel and the bathtub drain disappearing into it. This is a house with a basement and the tub is appx 9' below grade in the center of the house.
Thanks in advance.
Thanks in advance.
Yes - the tub is in, but the walls around it are not yet finished (there will be an access panel as well.) I just wasn't sure if the hole needed to be sealed in some way.
