replace jack-post with 4x4 or 4x6?
Old 06-25-08, 06:40 PM
caleyg's Avatar
OK I looked for a chart showing the load bearing capacity of lumber but couldn't find one. I'd like to remove a jack post and replace it with a 4x4 or 4x6. Is that jenerally possible?
The bearing capacity of the post is about 9,000 lbs. (I found that pretty easily. I don't know if that full capacity is being used but I'd like to keep at least that much capacity.
I know I can get one of those decorative aluminum posts but they just look a little too fancy for my taste. I'd like to just paint a post and put base around the bottom and the top.
Old 06-26-08, 11:09 AM
G
They make a product to go around posts like yours. It's called pole wrap and is avaliable at HD in the millwork department. I has a base and top for it.
Old 06-26-08, 12:51 PM
W
compressive strength
You might be able to borrow
Basic Lumber Engineering for Builders by Max Schwartz
by interlibrary loan
