Basement Tile removal/Asbestos/Adhesive
Old 07-10-08, 12:22 PM
R
My home was built in the early 50's and the orig. owners shortly thereafter installed tile to a portion of the basement. this tile was recently removed and it left a black, hard, adhesive which I would like to NOT have to remove. Can it be painted/sealed? It is likely that after the wall repair is done(excavation and all) that we will vinyl, or other floor covering over this.
Any guidance would be appreciated.
thanks-
Rick
Old 07-10-08, 03:18 PM
P
Temporarily Suspended
I wouldn't touch it until you are ready to install new flooring. At that time, you can cover it with 1/2 plywood and whatever floor you choose.
Old 07-10-08, 04:25 PM
HotxxxxxxxOKC's Avatar
Wrong.
This would be cutback adhesive, and it probably contains asbestos. I would get a sample and have it tested.
I would not "cover" it up either. Any new floor you put down will not install correctly over this.
