Vapor barrier between floors?
Old 07-20-08, 01:59 PM
D
My basement gets damp in the summer, and starts to smell mildewy. In one room on the first floor, the smell creeps up through the floorboards. To fix this, I put up insulation and a 4mil plastic vapor barrier on the bottom of the joists over this one area. Does this present any problems with the moisture? Should I do this everywhere in the basement?
Thanks!
Old 07-20-08, 06:45 PM
airman.1994's Avatar
Received 8 Votes on 8 Posts
Your not fixing the problem! The problem is the humidity in the basement. Buy a good dehumidifier and set it to 50%.
Old 07-21-08, 08:01 PM
H
what he said.
All you did was conjfine the problem to the basement, the mold is still there and will eventually get worse, and worse.
Old 07-22-08, 12:03 PM
D
plus the purpose of a vapor barrier is to keep the moisture in your LIVING Space from getting into a place it could condense when cold,not the other way around.
sounds like you definitely need a humidifier, and possibly some good ventilation.
