Wall Discoloration/Sediment?
Hello,
My husband and I are currently using our basement as a master bedroom (long story.) The walls are just the original cement block with a coat of paint on them from the previous owners. We have never had problems with water coming through the foundation, except during last year's flood, and that was only a trickle.
However, we have noticed a brownish/grey discoloration in certain areas along with some raised areas on the walls. It looks as if someone plastered some dirt on the wall and then painted over it. (Which, of course, is not the case.) I am planning to take a couple of pictures this evening. I honestly don't think it's mold, as it doesn't have any odor to it, but I could be wrong.
Do any of you know what this could be and how we can treat it/prevent it?
Thank you in advance for any help!
It sounds like efflourescense, but that is usually white patches on the block, which often blisters paint. It is hard to imagine dirt coming thru the block, but if it is very pourous block I supose it could happen.
