Mold in attic
Received 0 Votes
Mold in attic
I know this is probably a tired old question, but I have mold growing in my attic.
THe house is 4 years old. When it was built, the contractor vented the bathroom fans into the eves and the warm air and moisture was getting distributed back into my attic. I noticed black color mold growing. I finally figured out the issue and installed vents to vent the fans outside. That was 6 months ago and the mold seems to still be growing. It is growing up the OSB from the eves to the ridge vent. Anyone have any suggestions as to where I might look to find out where the moisture/heat continuse to come from? I noticed that the roofing nails are rusted on the bottoms so I assume this indicates a humidity issue.
Hi j, you say you vented the fans to the outside. Was that directly under or through your vented soffits? Soffit vented fans and even those that exit below the soffits are at risk of drawing the moisture right back into the attic.
The rusted roof nails can be a winter condensation problem. Is this a north or south facing roof area. What is your climate (where are you)? Are there any rusted nails or other indications elsewhere in the attic. And what is directly below that area. Is moist bathroom air leaking directly into the attic?
Bud
Bud
Received 0 Votes
mold
I had mold on my attic sheathing. I used a product called Cal-brite sold by a local pest control store. It is branded as a sanatizer. I sprayed it on in a pump up garden sprayer and the wood looks like new.
Now to hopefully fix the conditions that led to the mold.
Received 0 Votes
Cheap Powerful Mold Killer
Into a garden sprayer, add one (1) gallon of water, one (1) cup of household bleach, and one (1) cup of distilled white vinegar. Kills bacteria, viruses, mold, fungus and spores. Wear goggles. Use only in well ventilated areas, else use respirator.
Received 0 Votes
Into a garden sprayer, add one (1) gallon of water, one (1) cup of household bleach, and one (1) cup of distilled white vinegar. Kills bacteria, viruses, mold, fungus and spores. Wear goggles. Use only in well ventilated areas, else use respirator.>>>>>
I did try that however what it did not do is remove the mold stains from the sheathing (whether the mold was dead or not it looked the same) I figured I needed to scrub or sand which would have been a chore. the cal-brite restored the wood to like new appearance. Note that it is also sold as a deck and roof cleaner. I dont know if a box store cleaner would do the same? cal-brite did not need to be rinced.
