Moisture In Basement Wall Corners
Old 11-04-09, 07:36 PM
Woody10's Avatar
My house is brick with the basement walls coming above grade by about three feet. I have forced air electric heat. The walls in the upper are plaster.
It's cold out and the furnace has been running. I am getting moisture in the corners of my basement walls. I want to frame and insulate but can't figure out why they are wet.
It obviously has something to do with the heat being on and the cold outside.
The bedrooms above have considerable moisture on the windows in the mornings.
Any help would be appreciated.
Old 11-04-09, 07:38 PM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
If the windows have moisture on them you have to much RH in the house.
Old 11-04-09, 08:09 PM
Woody10's Avatar
So it's electric forced air. There is no air exchanger. How do I get the humdity in the house down over the winter time besides leaving the windows open?
Old 11-05-09, 03:52 AM
B
Received 47 Upvotes on 43 Posts
Hi woody, you need to determine the source of the moisture. The warm air inside the house can hold a lot of moisture. When it comes in contact with a cold/cool surface, moisture can condense on the glass or walls as you are experiencing.
Ant crawl space or basement areas with dirt floors? Any water leaking through walls in other areas. Was this basement area open (vented) during the summer? Do you know what you have for insulation?
Bud
Old 11-05-09, 04:23 AM
Best way is to open a window a inch and turn on a bath fan.
