Prep to paint basement floor questions
Old 02-03-10, 04:55 PM
Home wrecker's Avatar
The floor is in good condition. It does not appear to have any kind of sealer on it, but the floor does seem to have a polished look to it???
I plan to use a 2 part epoxy to paint. The basement is 26'x 32'. It was poured in sections which left obvious seams. Do I need to fill these seams before I can paint? If I do then what should I use so that the floor still has a smooth finish.
Is there an one paint product (brand) better than another or is it personal preference? There is one seam that has minor seepage after a super hard rain, other than that the floor is dry. Is the seepage a concern when chosing the paint?
Old 02-04-10, 08:52 AM
B
Received 1 Vote on 1 Post
Hi Homewrecker:
Is there any reason you prefer to use paint?
In the past, I have had problems with paint lifting up from concrete. For our last four homes, I've had good experience using a concrete stain. It keeps the dust to a minimum, is easy to apply and holds up well. Because you can get a wide choice of colors, my wife thinks it really brightens the basements.
In one house, we had some leakage from a heavy rain and the stain handled it with minot touch up's until we installed a sump pump.
Old 02-04-10, 09:39 AM
Received 408 Votes on 364 Posts
The seepage is definitely a concern! it's hard for any coating to stay adhered if there is moisture coming thru from the back side.
I'd also recommend a concrete stain over paint, it's less likely to peel. I'm partial to the H&C concrete stain sold at SWP. The seams in the concrete, are they just visible? or can you also feel them? If they are just visible, 1-2 coats of solid stain should make them go away. Hard to say how they will look if there is a difference in the concrete texture.
I would be concerned about the area where you have a little seepage, not sure what would be the best fix
Old 02-04-10, 12:21 PM
The seams are just that, seams, they are edged where the two slabs meet. In my case the floor was so big they poured it in 4 different sections.
I thought the whole purpose of a 2 part epoxy was to hold water out??? The product I was considering is Rustoleum's epoxy shield for basement floors. Unlike the one for garage floors this one is (or so I thought) supposed to seal the floor to prevent any seep through.
Anybody out there used it?????
